RCU Forums - View Single Post - pull-pull setup for pattern
Old 12-07-2009 | 02:25 PM
JAS's Avatar
JAS
Default RE: pull-pull setup for pattern
Measure the horn and get an arm that matches the distance spread between the holes. I use a Du-Bro HD arm ([link=http://www.shopatron.com/products/productdetail/part_number=670/101.0.1.1]HD arms[/link]) and 4-40 pull-pull cable system ([link=http://www.shopatron.com/products/productdetail/part_number=518/101.0.1.1]Cable system[/link]), parallel and it stays tight. Make sure the horn holes are inline with the rudder hinge line.
ID:	1329139   Click image for larger version
ID:	1329140   Click image for larger version
ID:	1329141   Click image for larger version
ID:	1329142   Click image for larger version
