RE: Help with dialing in Lama V3 please.
Hi, Ruben:
If you've already tried the trims all the way to the left-forward position,then go to the joints between servos and collective and correct the length till you get the trims back to the center. Nevertheless you may need to make corrections on your trims in every flight.
Good luck!
