RCU Forums - View Single Post - Goldberg Extra 300
Old 12-07-2009 | 07:20 PM
  #813
Gray Beard
My Feedback: (-1)
Default RE: Goldberg Extra 300
I went out and set up a piece of balsa just like I would do if I was going to use CA hinges, shot in a load of Pacer Hinge Glue then stuffed the hinge into the slot, that was a lot tougher then it sounds, Pacer is pretty thick. I let it set up for three and a half hours, nothing better to do, it's raining out today. After the 3.5 hours I gave the hinge a good tug, it didn't budge so I stuck the hinge in the vise and save the wood a pull, it came out this time. The glue was still tacky but where it was set up there is wood that clung to the hinge, Pacer is some very good glue and if it was squished in to the slot first then the hinges pushed in then it will hold very well. If the glue was just flowed onto the hinge there is no way for it to flow into the hinge slot and work like CA.
Gene
ID:	1329354   Click image for larger version
ID:	1329355   Click image for larger version
ID:	1329356   Click image for larger version
ID:	1329357   Click image for larger version
