RCU Forums - View Single Post - SMALL DISPLACEMENT FOUR STROKE GLOW TO GAS CONVERSION
Old 12-09-2009 | 11:23 AM
Pull Up Now!'s Avatar
Pull Up Now!
Default RE: SMALL DISPLACEMENT FOUR STROKE GLOW TO GAS CONVERSION
ORIGINAL: Pull Up Now!
Another idea occured to me. Besides having oil clog the pulse tube and eventually the pump diaphragm, I've noticed that the engine crank rotation is severely restricted when the pulse tube is connected. This will rob horsepower due to piston backpressure. It also would inhibit blowby, possibly leading to bearing failure. So.....here's the idea: Add a tee to the line, with a tiny bleed screw. Adjust the screw slightly open just enough to get about 4-6psi (measure this) at the regulator, and the rest is vented to ambient. This is a compromise solution, but might relieve the crankcase backpressure enough to prevent performance loss. Comments?
Any comments on the above idea? I'm open to suggestions on this as a way to use carbs with traditional positive/negative pulse surge diaphragms (no spring).
