RCU Forums - View Single Post - Chip Hyde's Cap-X - Building & Flying
Old 12-10-2009 | 09:05 PM
  #1048
boex
Default RE: Chip Hyde's Cap-X - Building & Flying
ORIGINAL: Lightning Fan
All I can tell you is that a 42 does a very nice job. I guess your 30 would spin an 18 x 10? I'm using a 20 x 10, and the two engines would be at the same RPM ... so you are losing quite a bit.
It depends on the flying you are doing, also. I have a 52 in a H9 CAP with a 80'' wing, and its performance is like this one ... unlimited vertical. I am sure the 30 would fly it, but you would not get 3D out of it, I don't think.
Thanks for your advice. My DLE 30 would be spinning a 19x8, I believe that would give me a static thrust close to the advertised 8.5kg. The cap weighs around 5.5kg, so if my numbers are correct, wouldn't I be able to 3d with authority?
