RCU Forums - View Single Post - Sturm Tiger RC conversion that shoots :)
Old 12-10-2009 | 09:19 PM
pl_09
Default RE: Sturm Tiger RC conversion that shoots :)
Use a slow moving drill to drill thru the axle. To secure the piano wire inside the axle, I bend 3 mm of the tip of the outer end of wire and anchor it into the axle . After secured with glue, and put into position inside tank, I bend the other end so that the bent wire rest on the inside of the opposite side of the tank. It is easily seen from the photo in the video.
