I've done a few on a High Point prop balancer but you can also do it on the Dubro
Use the pointed fixed cone on the front of the flywheel and the the flat side of the moveable cone on the back side.
Use a air powered die grinder or file to remove material from the heavy side. Stay away from the steel counter weight
