RCU Forums - View Single Post - Axe 400 RTF Tail Rotor Failure First Flight
Old 12-12-2009 | 11:06 PM
redneckjedi
Default RE: Axe 400 RTF Tail Rotor Failure First Flight
The belt tension seem adequate. Did some more checking and found that the Tail Rotor Belt Drive Gear (TRBDG) seems broken. The motor gear turns the bigger lower gear on the TRBDG. I can see the spindle turning going up to the smaller gear on the TRBDG, but the smaller gear isn't turning. Any thoughts?
