RCU Forums - View Single Post - Another Skymaster Viper
Old 12-14-2009 | 03:03 AM
  #609
gonzalom's Avatar
gonzalom
Default RE: Another Skymaster Viper
ORIGINAL: DENTO
ORIGINAL: hangarman
ORIGINAL: DENTO
IF you are going fishing ,You would have heard about the watch chain trick
REGARDS John
No, educate me!
H
<br type=''_moz'' />
G-DAY HANGERMAN
I cut a 15mm hole across inside the wing from the servo box towards the leading edge forward of the wing tube box allso a 20mm hole in the root rib forward of the wing tube hole then a mt of fine watch chain from BUNNINGS here, lowes over there,Then dropped it through the hole in the servo box hang onto one end hold the wing verticle and the chain will drop through hopefully, BEEN FISHING ,HEY hope you understand all that
REGARDS
JOHN
John, I follow the fishing technique but not good results so far...... any advice? or do you guys have some sort of drawing? are you guys doing the airlines too in that way? I didn't used a chain... instead a wool line with a nut at the end..... I am a good fisherman but I don't seem to get this one.
Regards,
Gonzalo
