Way back.....my EMCs used pulleys on both the servo and rudder ends.....looks cool....works....no real advantage in practice. Since I started flying Wistmodel stuff, I use the horns they supply....slight ackerman on the servo end.
Recently, I switched from the servo end shown by Vince to clevises on both ends...because I was breaking cables after 200-300 flights as they frayed on the servo arm. Lots more pressure and wear on cables now than when the 2M stuff was smaller.
Regards,
Dave
ORIGINAL: vbortone
Just in case. If you need to make it simpler and save some weight you could thread the wire as shown in the picture.
VB
