RCU Forums - View Single Post - pull-pull setup for pattern
Old 12-14-2009 | 12:41 PM
vbortone
Default RE: pull-pull setup for pattern
Hi Dave,
I think I got the idea from you. I never had problems. I remember that I cut the sharp edge of the horn hole with a Xacto knife. Probably this is the reason I never had problems. This sharp edge effect is also present using clevises. In those cases, I grind the sharp edges in the connecting rods to reduce the chance of cutting the cable. Well in FAI you are doing the knife edge loops. That puts a lot of pressure on the cables.
Vince
