rotor servo issue
I have an Exceed RC G2 with all factory parts. No upgrades. I am having an issuee with my tail rotor servo. After initializing with the Tx the servo wants to continually move out of 90 degrees to its maximum right position. I have tried to initialize the servo without to connecting rod attached so the gyro will put the servo at its neutral (90) position. Then attached the connecting rod at 90 degrees. Then I position the rotor at 0 degrees pitch. When I throttle up and then back down, the servo stays at its maximum right position. How do I adjust to make the servo return to a relative 90 degree position? Gyro settings are Nor & Rev. I do not believe I have a digital servo but then I do not know how to tell the difference.
Thanks in advance for any help/
Tim</p>
