RCU Forums - View Single Post - WHATS CAUSING THIS PROBLEM??
Old 12-14-2009 | 03:56 PM
dknovick's Avatar
dknovick
Default RE: WHATS CAUSING THIS PROBLEM??
ORIGINAL: BUBBA633
A little background info:
I had a pretty bad crash recently where the nose got planted pretty well in the ground and I damaged the main blades, feathering shaft
flybar, main gear and tail boom.
If you're sure it's not the batteries, you may also want to check your electronics. You may have damaged something else in the crash.
-Dave
