Himoto Brake Upgrade
Having problems with the brakes on your Himoto? Here is what you can do. Take out the E-3001 throttle servo, and change to the E-9001 servo. (DO NOTSWITCH WITH THE STEERING SERVO, ORDER A NEW ONE) Start with the front and tighten up the (2) S.H.C.S. that hold the pads in place, alternating them and turning them 1/4 turns. After each 1/4 turn pick up the back of the rc and roll it till it drags. Then back the S.H.C.S. off 1/8 turn. Repeatthe process for the rear brakes.Follow this and there will be no need to double up on the brake pads.
