RCU Forums - View Single Post - Engine Test Fixture
Old 12-15-2009 | 05:32 AM
planebasher
Default RE: Engine Test Fixture
I realize that; after 800 hours in a bass boat.
You also cannot adjust the carb on an unloaded 2 stroke engine.
The purpose of the fixture, at least for me was to put a load on the engine to see what max rpm could be obtained with a load and to also test the transition from idle to WOT.
But the Prop really does not cavitate that much. It will lift the top off of the container; with a 12 inch long piece of RailRoad Track sitting on it; that is why I had to screw the top down.
It serves my purpose; better than slinging a rod at 20,000.
