RE: Himoto Brake Upgrade
Ok guys, I am trying something new out and I will let you know how it works. I just got the second set of brakes, and I purchased a product called RUBBERIZEIT. You can get it in two forms, a spray and a dip. I got a can of the dip for under $10.00 at the local hardware store. It comes in red, blue, and yellow. It is a durable, anti-skidrubber coating. Its the same thing that is on the handle of most hand tools, like pliers. My plan is to coatsixbrake pads with two coats.Iwillinstall 3 pads and 2 discs on the front and the rear, like so, pad, disk, pad, disk, pad.I will lightly sand flat spots on the rubber coating to insure the greatest amount of contact. I willpost back in a few daysto tell how it works.
