RE: SUPER REAPER MAIDEN FLIGHT SOON NEED ADVISES
Wayne22, Hi,
I like the pic you posted here, do you have more of your Reaper to share please ???
siddus74, Hi,
Futaba servos, and 4.8volts,
I have a set of 9255, top heli servos as listed by futaba, came with a 12fg set i bought last year, now i to was worried about the voltage, as im going to run them in my new PST Reaction, on a Powerbox Gemini, at 5.9volts... Have been told that its not a problem, by Powerbox, and Intairco in Australia... Also going to use 9252, and 9202 servos in the same setup...
I think one point to mention, is the voltage thru the Powerbox set, doesnt exceed 6volts, where as a 6volt pack, off charge will got to near 7volts...
Hope this helps you...
Cheers Jeremy.
