RCU Forums - View Single Post - CMP Cessna 50 ARF- Hinges
Old 12-17-2009 | 12:04 PM
blvdbuzzard
Default RE: CMP Cessna 50 ARF- Hinges
They should be hinge points. I have read that the ones that come in the ARF are brittle and break very easy. the ones that came in my ARF are bendy. I was going to replace them with Robart hinge points.
You can use epoxy, gorilla glue, thick CA. I used epoxy. Put a drop of oil on the hinge to lube it up so the epoxy does not stick to the hinge and bnid it.
Dru.
