 CMP Cessna 50 ARF- Hinges >
Old 12-17-2009 | 08:32 AM
gazzazh's Avatar
Default CMP Cessna 50 ARF- Hinges
Merry Xmas ,
I just recived my CMP Cessna, and i am ready to start building it. Ihave only built 2 planes so far, the Hangar solo star trainer and the Hangar 9 cherokee. With both planes I used epoxy to glue the hinges as per the instruction of the manual. With the Cessna, the hinges are of a diffrent type, anyone who already bult this plane, please explain the procedure on gluing the hinges on this plane. I dont want to mess things up. Thank you so much
cheers
Old 12-17-2009 | 10:50 AM
MinnFlyer's Avatar
Default RE: CMP Cessna 50 ARF- Hinges
If they are CA Hinges, read this:
http://www.rcuniverse.com/magazine/a...rticle_id=1180
Old 12-17-2009 | 12:04 PM
They should be hinge points. I have read that the ones that come in the ARF are brittle and break very easy. the ones that came in my ARF are bendy. I was going to replace them with Robart hinge points.
You can use epoxy, gorilla glue, thick CA. I used epoxy. Put a drop of oil on the hinge to lube it up so the epoxy does not stick to the hinge and bnid it.
Dru.
Old 12-19-2009 | 12:03 AM
gazzazh's Avatar
thanks for the advice... i will use epoxy.. and will drop oil on the hinge points .. cheers<div>
</div>
