RE: Factory Pitch/Throttle curves Axe Cp
These are the measured values I had before I changed to a DX7 TX.
Throttle curves:
Normal: 0.0%, 36.0%, 72.0%, 83.5%, 100%
Idle Up: 100.0%, 83.5%, 72.0%, 83.5%, 100%
Pitch curves:
Normal: 40.0%, 45.0%, 50.0%, 72.5%, 100.0%
Idle Up: 0.0%, 27.5%, 50.0%, 72.5%, 100.0%
However, there is no way of changing them using the old version 1 TX, on the V3 TX there was some slight adjustments you could do using the external pots on the TX.
Shadow
