If this works, keep in mind that diffrent companies make this product, and (NOTALLARETHESAME). The one I used is resistent to chemicals, and the temperature range is-30°F to 200°F. Here is some information reguarding the coating I used.
SPECIFICATIONS:
Solids: (wt.) 24%
Durometer: shore A (ASTM D -2240) 70
Tensile: (ASTM D -638) 3,740psi
Salt spray: (ASTM B -117) passed 1,000 hours
Elongation: (ASTM D -638) 430%
Weatherability: (ASTM G -53) 3-5 years: PLASTI DIP 7 -10 years: PLASTI DIP U.V. Stable
Cut resistance: (ASTM D -1044) very good
Stone abrasion: (ASTM D -3170) excellent
Temperature use range: -30°F to 200°F.
Shelf life: 1 year at 77°F after opening
Viscosity range: 80 – 100 K.U. @ 77 °F (+/- 2°F)
Chemical resistance: acids, alkalines, pollutants: excellent petroleums: limited
Permeability: (ASTM E -96) .03 grains/sq. ft./hr.
Coverage: 30 sq.ft. per gallon at 15 milsPlasti Dip multi-purpose coatings allow you to rubberize just about anything!
Plasti Dip multi-purpose coatings allow you to rubberize just about anything! Plasti Dip is a flexible synthetic multi-purpose coating that exhibits excellent moisture, acid, alkaline, and abrasion resistance.
[*]Flexible - Won't crack, chip, or become brittle[*]Insulates - Electrical shock, vibration, and heat[*]Grip - Provides safe non-slip comfort and control[*]Durable - Resists weather, chemicals, impact, and abrasion[/list]
