Wayne22, Hi,
I like the pic you posted here, do you have more of your Reaper to share please ???
Thanks, I do, but they are old ones...
How have you found the Reaper to build/assemble ???
It is pretty easy to build...square box fuselage, the leading edge needs to be shaped. The vertical fin mounts need to be reinforced..a couple of Reapers have had the fins come loose and flutter in flight...
