RE: Factory Pitch/Throttle curves Axe Cp
Hey Gary, Here are some more details of the programming I did using the DX7.
Model name: MX300
Model 1: Heli DSM
Swash Type: 3 servos 120'
Input Select: AUX2-INH GEAR-gear
THRO Recovery-INH
TRAINER-INH
I added the programming mix so that any cyclic/pitch change gives you 20% increase in throttle, this keeps the headspeed up and the response lag down (if you do not have Bell-Hiller Mixing an the head). With BH mixing it will respond like a hummingbird on JOLT soda!
Prog Mix 1: ELEV-THRO Rate:+20% -20% SW:ON Offset:0
Prog Mix 2: AILE-THRO Rate:+20% -20% SW:ON Offset:0
Prog Mix 3: PIT-THRO Rate:+20% 0% SW:ON Offset:0
Revo Mix: ALL ZEROS (unused)
Throttle curves:
Normal: 0.0%, 36.0%, 72.0%, 83.5%, 100%
ST1: 100.0%, 83.5%, 72.0%, 83.5%, 100%
ST2: 100.0% (across the board!)
Pitch curves:
Normal: 40.0%, 45.0%, 50.0%, 72.5%, 100.0%
ST1: 0.0%, 27.5%, 50.0%, 72.5%, 100.0%
ST2: (same as ST1)
Thro HOLD: Hold Pos 0% SW:AUX 2 (Only use after rotor has stopped, will strip main gear with BL motor in flight)
Swash Mix: 3-servos 120' EXP-INH
AILE -100%
ELEV -100%
PIT -60%
Travel Adjust: ALL 100%
Sub-Trim: Adjust as nessasary with your servos & linkages (try and keep values low or 0 on RUD if using Belt Driven Tail & servo)
Reverse Switches #4 & #6 (All others are NORMAL 1,2,3,5,7)
AUTO D/R EXP NORM-INH
ST-1 P0
ST-2 P1
HOLD INH
D/R & EXP Position 0 (RUD,ELEV,AILE) d/r 50%
Position 1 (RUD,ELEV,AILE) d/r 100%
Shadow
