RCU Forums - View Single Post - improved vibration
Old 12-19-2009 | 12:27 AM
  #55
gasayers
Default RE: improved vibration
Well I've found part of my problem. After reading that the 18" prop should have no more than 1mm play at the tips I removed the gasket.
Now the gears are "bottoming out". Trouble is if I get the gaskets to stop the gears bottoming out then I get more than 1mm play on the prop.
Conundrum!
