RE: Entry level smaller pattern kit.
Now that truly is a nose ring Vince. Wow, good work. I will use an OS120AX on my FS if and when I get one. I don't think the 2 cycle engines, (and that 120AX is a very smooth one), need soft mounts or nose rings, at least I have never seen those things on any engines except 4 cycle ones. Would any of you guys use a Hyde mount and the nose ring if you were using an OS120AX??
