RCU Forums - View Single Post - tems problem..
Old 12-20-2009 | 07:25 AM
davo580
Default RE: tems problem..
i don't know if it is correct. but when doing the starting learn the only way it will start is when i put the throttle trim to the middle then do the full throttle then back to idle then put trim all the way up only then the turbine will go through it's start up proceedure, i did it by the instructons but it will only start that way.
my other turbine which is a wren 54 mk3 starts full trim and then the throtlle full then idle
