tems problem..
CA
tems shows 0deg c (new termocouple and i am sure it is ok) also glow fail new plug will not reset still shows glow fail plug is ok
Arden
Arden
CA
the probe is new from pst i have switched polarity and i get same 0 c i found out before the probe opened up that if the polarity is changed that i woulld get a reading 22c but put heat to it and it would go to neg 0 c also it keeps blowing the glow blugs
Arden
Arden
i don't know if it is correct. but when doing the starting learn the only way it will start is when i put the throttle trim to the middle then do the full throttle then back to idle then put trim all the way up only then the turbine will go through it's start up proceedure, i did it by the instructons but it will only start that way.
my other turbine which is a wren 54 mk3 starts full trim and then the throtlle full then idle
