RCU Forums - View Single Post - Question about a refurb.
Old 12-22-2009 | 12:08 PM
Mr67Stang's Avatar
Mr67Stang
Default RE: Question about a refurb.
ORIGINAL: vpresley
If that does not work, try a heat gun on the mount, being careful to get it to hot. Heat softens epoxy.
Vince
Un-bolt the engine mount. If it does not easily come off the firewall. Get a helper to hold the plane. Heat the base of the aluminium engine mount with a monocoat heat gun while holding the mount with plyers to avoid burning your fingers. These heat guns put out about 400 degree air. Gently pull/twist/rock the mount as the epoxy softens. It will come loose without damaging the firewall.
