RCU Forums - View Single Post - Pin Switch
Thread: Pin Switch
Old 12-23-2009 | 08:01 PM
j.duncker's Avatar
j.duncker
Default RE: Pin Switch
ORIGINAL: huck1199
You could use an RCA speaker jack. The kind that turns off the speaker when you plug in your head phones. Then just put an RCA plug in when the plane is not in use.
I do not like using these on IC powered models as I have had problems with vibration and intermittent contacts. Fine on gliders though.
