RE: First time engine start
Id clear the old fuel out of the engine. set your needle to 2 1/2 open. Remove the glow plug and turn it over until the fuel stops gushing out of the plug hole. Keep doing it till you can see only spray coming out the plug hole. Check to make sure the plug is working. If it is insert it and try to start the engine without priming it Using figers or starter you should get a result.
