RE: crashed heli multi problems..help!
# 1 Did you plug in the servos yourself, or was it plugged in at the factory?
# 2 Loose belt, or loose tail pinion(s)?
#3 Normal
#4 I assume you mean "tail fin", Not really needed for the flying you'll be doing for now... Hovering.
About #4... Did it break because of a main blade strike?? Your feathering and main shaft have a great possibility of being bent right now.
You should post a vid or pic of the problems.
