RCU Forums - View Single Post - crashed heli multi problems..help!
Old 12-27-2009 | 07:51 PM
FILE IFR 's Avatar
FILE IFR
Default RE: crashed heli multi problems..help!
ORIGINAL: tacannav
The servos were put in by the factory, as for the heli belt, it is not loose or anything like that, the tension seems ok,.....and yes, I meant the horizontal tail blade, not the vertical fin, like the ones that stick up in the back of a shark,.....this one is like the ones that come out the sides of his abdomen for horizontal stability.
Ok. It's really called a 'Tail Fin' not tail blade...... How did it break?? Tail blades are something different.
Is there any way the transmitter will move the 3 cyclic servos??? That's the main and biggest problem so far.
FYI: For safety sake, unplug your motor (2 of the 3 wires will do) and do all your checks then.
