ORIGINAL: tacannav
....about the 3 cyclic servos, I can move them with the right side joystick but the left side joystick does not move them, it only works the throttle turning the main rotor
Are you saying when you move the LEFT stick UP and DOWN (collective/throttle), the 3 servos do not move up or down in unison??
Tail: your pinion(s) may be slipping from the mishap you encountered.
I know you're new, so I'll give you an R/C heli part terminology tip (plz do not take offense [8D])... The 'Feathering Shaft'
OR sometimes called the 'Spindle' cannot be seen, it's the shaft going horizontal through the headblock connecting the main blade grips. The 'Tail Rotor Shaft' has the tail pinion gear and tail blade assembly mounted to it.... This shaft can't tolerate
ANY bend whatsoever.
