RCU Forums - View Single Post - GP Synapse
Thread: GP Synapse
Old 12-28-2009 | 07:49 AM
ftjets's Avatar
ftjets
Default RE: GP Synapse
ORIGINAL: rcfanaticmark
I got a Synapse EDF as a gift and have a question for those of you who own one. I am using Spektrum DX6i with an AR500 receiver. After following the set up as directed for elevon mixing, I ended up with the left stick directions mixed up and I can't seem to find a solution. The usual set up of up and down movement producing lift and descent are now moving the plane left and right and left and right movement is producing lift and descent. Has anyone else had this problem? What 's the solution? Thanks!
Wish i could help but i am 100% Futaba. Elevon set-up is pretty simple on my 7C. Don't know if the Spektrum has the same features but on my Futaba there is the ability to program control throws in + or - percentages. Setting them in the wrong direction will cause the controls to move in the wrong direction for the given command. Hope that helps.
