RCU Forums - View Single Post - GP Synapse
Thread: GP Synapse
Old 12-29-2009 | 04:01 AM
ftjets's Avatar
ftjets
Default RE: GP Synapse
ORIGINAL: rcfanaticmark
Thanks for the info! I have found the reverse throws on my transmitter, but it only changes the direction of the ailerons not the potentiomters. I will keep trying and if all else fails, talk with horizon hobby.
Mark, sorry i missed it on the first look but i believe that your problem is simple to correct. I was not referring to the servo reverse function but that doesn't matter anyway. Page 45 in your manual shows the elevon setup. Note that you must plug the left elevon servo into the aileron port on your receiver and the right elevon servo into the elevator port on your receiver. I believe that if you check this you will find that they are reversed and the problem will be corrected.
