RCU Forums - View Single Post - Perry oscillating pump?
Old 12-31-2009 | 04:40 PM
  #52
OSUAV8R
Default RE: try uniflow setup..!
OK, here is my problem...  I am running an OS 70FS and need to run a VP-20 because of the level of my tank.
  The engine runs well with the high speed needle set at about 1 1/2 turns open.  I connected the VP-20 and set it open about 5/6 of a turn from fully closed.  At this setting I had to close the needle to 1 turn open to run well.  I assumed that the pump was pumpoing way to much fuel so I closed the pump about 1/6 of a turn and returned the needle valve to where it was pre-pump.  The engine would sputter and die after I removed the glow plug battery.  Any Help would be great!  This is my first FS  My Goal is to get the Perry working.. not spend more on a regulator
Nate
