RCU Forums - View Single Post - Comp ARF Valiant
Old 01-01-2010 | 10:06 AM
  #86
eryildirim
Default RE: Comp ARF Valiant
Thank you.
The other part of stab works very well. The elevator moves to both sides equally.
As seen in the picture, there is a small hole. It is enough to see inside with a
+3.00 telescopic lens under bright transillimunation. Unfortunately there is not any head of wire to hold. It is perfectly aligned with the hinge.
I tried to hit the stab on the side of the hole gently ,expecting the shifting of the wire but noting happened.
Also I drilled a hole other side of the elevator by using transillimunation to push the axe wire with a 1 mm wire. I knew that the probability of to do it was very low. I could not reach to the axe wire but the hinge.
I don't know internal structure of the elevator exactly. Only I can guess it comparing to the rudder. So to make a minimal damage on a very well painted and finished model, I have to chose a correct
place for entrance. Any knowledge is important for me.
