RCU Forums - View Single Post - 3000 kv HEAT PROBLEMS>>HELP NEEDED.
Old 01-01-2010 | 05:47 PM
westbeach
Default RE: 3000 kv HEAT PROBLEMS>>HELP NEEDED.
for a 3000 KV motor, you can try running a 2S lipo (7.4V) Your run time will definitely be short, bring it in within a minute to check the temp of the motor. If it is okay, you can run it for another minute. SRT10 said it best, lower motor KV, higher batt volts is the way to do it right.
