RCU Forums - View Single Post - 3000 kv HEAT PROBLEMS>>HELP NEEDED.
Old 01-01-2010 | 07:24 PM
srt10
My Feedback: (20)
Default RE: 3000 kv HEAT PROBLEMS>>HELP NEEDED.
ORIGINAL: ludakris308
sr10.. ive got 2>> 3 plate lithium polymer 11.1V batteries, is that not enough volts! as ive seen other turn there boats into 22.2V boats with great performance, but at the hobbie shop down the road he has a 22.2 V batterie there in a single pack >would that be better (drawing it from 1 single destination! with the lower kv as i dont want to go slower i want it all!! lol
If your running on 6s (22.2) that motor and esc will not survive!
high kv and high volts = smoke!
your system would be pulling way to many amps..
if you want to run 6s you need a motor with a kv of 1200 or so with a 42-45mm prop
