RCU Forums - View Single Post - Help! Need to add weights. Where?
Old 01-01-2010 | 07:26 PM
StevL
Default RE: Help! Need to add weights. Where?
If you can move weight do that, this should always be your first option. It may mean cutting a little covering and putting you batteries back then replace the covering.
I hate to add weight, it will increase the wing loading and slightly decrease overall performence.
If you must add weight do it a far back as possible, this way you will add the least amount.
