ORIGINAL: rebuilder
US dollars..........
You may also be able to use an ''L'' model motor.................i was thinking your boat was a bit bigger......couldnt remember off the top of my head.............its the 26'' right?
This should work as well....................you can always prop up just a bit with these lower kv motors to gain a little more speed.
14L or 13L
http://www.offshoreelectrics.com/pro...i-540L&cat=116
So..................as i had already suggested.....in post #2,#4,#6 and #8.............
lower kv..................like the L - 1755................and 4s
