RE: Help! Need to add weights. Where?
Trainer type airplanes are typically set-up a little bit nose heavy. Your PTS Mustang is a fairly well proven design...it should be OK the way it is.
Save the removal of the flywheel tip for later, when you're ready for more responsive controls.
