RE: how to align turbine and tail pipe accurately
You guys have come up with some very impressive pipe centering systems here. They clearly show a lot of attention to detail. If you guys could comment on a question I have - is there anything materially wrong with just using a finely graduated ruler measured up against the mounted turbine tailcone, to reference the correct placement of the pipe bellmouth inlet? That is what I've done in the past with good results, so far as I know to base "good results" on at least.
