RCU Forums - View Single Post - Battery Charging for Pattern
Old 01-02-2010 | 01:53 PM
DaveL322's Avatar
DaveL322
Default RE: Battery Charging for Pattern
Joe,
For equal power (watts), the amps will be lower on 10S. Lighter planes should use less mah for equal flights, and 9.5 lbs is certainly a full 10% lighter than the average electric - I'd think that would translate into a 10% reduction in mah used for equal flights for patterns with big verticals - probably only 5% tho on less demanding patterns.
Regards,
Dave
