RE: SMALL DISPLACEMENT FOUR STROKE GLOW TO GAS CONVERSION
The standard Saito to ignition conversion has the Hall effect sensor bracket mounted under the two fron screws of the cam box.
The magnet hub is an aluminum collar held fast on the existing prop drive washer by a set screw. If the collar slip initially it is no problem readjusting the timing to 28 degrees. Then it never seems to slip after that.
