ORIGINAL: krproton
Hello Guitarman.
I've been flying planes similar to yours with similar power plants - several of the 27% GP Extra 330S ARF and I also have the Edge 540 ARF in the same series. Both are powered by DL50s and both required tail weight - around 2-1/2 oz. in the Extra if my memory serves me correct. These planes weren't designed for 50cc engines, thus the nose-heavy situation. Rest assured both of mine fly delightfully balanced as recommended with the tail weight. On my most recent Extra I even mounted the battery near the horizontal stab and it STILL required some tail weight (although I used the pull/pull rudder servo setup instead of the tail-mounted servo which probably would have negated the additional ballast).
Here are some pics of the lead in the tail of one of my Extras.
Hope this helps.
Tim
Thanks Tim. Did you cut out the balsa, or did you just remove the monocote?
