RE: 4 Stroke jam nuts
I don't think you're going to find the true factory style Jam nuts with the sleeve on the end to fit inside the larger nut at Lowe's or Home Depot. That said, simply adding a second regular nut for safety to avoid throwing props should work and this should be available at any hardware store.
