RE: SMALL DISPLACEMENT FOUR STROKE GLOW TO GAS CONVERSION
My point is that with the ground lead surrounding the high tension lead the chances of it taking the path of the sensor are pretty small. The path is right there all the time. Maybe if you peeled the shielding back far enough from the core wire you'd have problems. but you shouldn't be powering up the ignition in that condition.
