RCU Forums - View Single Post - SMALL DISPLACEMENT FOUR STROKE GLOW TO GAS CONVERSION
Old 01-05-2010 | 10:04 PM
  #146
Pull Up Now!'s Avatar
Pull Up Now!
Default RE: SMALL DISPLACEMENT FOUR STROKE GLOW TO GAS CONVERSION
ORIGINAL: gkamysz
The CH 1/4-32 plug boots have not come loose in my use. What kind of battery are you using? Are you using an electronic ignition kill switch? It's rare to see an intermittent hall sensor. They either work or they don't. Unfortunately, I don't know about the self sparking.
6 volt supply, as specified on the outside of the ignition box. No kill switch. To stop the engine, I just unplug the battery.
