RE: 4 Stroke jam nuts
Your Lowes and other hardware stores are sure different than the ones I have access to. If your needing the lock nuts used on the prop shaft, you will need metric nuts. Saito nuts are easiest to obtain right from Horizon and the OS's can be had from Hobby people if you can find the size and buy the magnum equivalent.
fred
